We use a neat set up for storage and enables moving engines around in the race trailer. Imagine a 4 wheel furniture Dolly that is about 24' x 30" and only about 4 inches off the ground. About centered on the 30 " length is a square tube that has a steel motor mount welded to it and down to the Dolly. The engine pan sets on top of the Dolly and it secured level by being bolted to the motor mount.
This set up will now roll around without tipping over but is low to the ground and will tuck under a bench. I left measurements off this description as you can make any size needed but about the footprint of the engine makes it safe and easy to wheel around.
