Old 07-07-2008, 09:42 PM
Garage10's Avatar
Garage10 Garage10 is offline
Cobra Make, Engine: west Coast Cobra FRP 460, Tremec 5 sp, Ford 9" rear
Hi Blas- No screen, just clean new rad. Could have trapped air but think I have it all out.Hole is on top 180 deg thermostat.Lower hose going to pump seams to have slinky slightly kinked but doesn't appear to be collapsing when I watch it running.I am replacing with coolflex hose. Car gets to 230F while sitting idling.single 16" puller fan working correct on 23"x16" 4 core aluminum rad. No pusher.timing 14 initial 35 total.using 30% antifreeze with 1 bottle water wetter. West coast comes with two temp gauges that are fairly similar in temp.
FWB- I will have to check out the heater thing. The rad cap is new and seams fine.
Thanks to all
Brent
Get in,buckle up,hang on and scream all you want cause nobody's gonna hear you over the sidepipes!
