Thread: Side Pipes
Old 07-08-2008, 01:54 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
I don't believe the gaskets are always installed...
From my notes:
The best is Ultra Copper, good to 700f, then High Temp Red, good to 650f and finally Ultra Black good to 625f. I Any will work on a W or 385, I generally use the Copper on an FE just because the water jackets set back form the flange, so an FE flange sees a little higher temp.
There is a new product from Loctite called Gasket eliminator and it has a temp value of 880 F.
Install headers sans gaskets using Ultra High Temp Red Permatex. Put it on the header flange (thick but not overly so) and allow it to cure a few minutes and then install the headers with the bolts finger tight, after an hour or so I torque the bolts.
SPFWiringDiagrams@Comcast.net
