  #202 (permalink)
Old 07-09-2008, 11:10 PM
wanab5150's Avatar
wanab5150 wanab5150 is offline
Cobra Make, Engine: Superformance #2769 Roush 427R Dart Block
For all you guys with Superformance removing your spinners/ wheels........
The first several times I removed my spinners I dinged them. I used a large plastic mallet as I was told not to use a Lead or rubber hammer because of more damage.
All was fine except when you hit the spinner on the edge, you will get some damage OR, if your spinners are on really tight you will have to beat the crap out of the spinners and WILL damage them. ALSO, if the hammer slips off the spinner, expecially in the deep 17 inch wheels, you will possibly ding the polished part of the wheel. The spinners buff out really easy because they are very soft aluminum. I sanded the dings out with #400 then #1500 and they polished out super easy and look new. The wheel I dinged to 3 hours to remove the ding and polish it out.
Solution...... I called "Vintage Wheel" who was found to be the supplier for Superformance. I asked about the various hammers and the answer blew me away. He said go to Home Depot....buy a 2 ft. long 1"x4" piece of oak. place the end of the oak against the spinner (flat) and the middle of the piece of oak against the tire as a brace, and hit it with a STEEL hammer. Due to the fact the oak is 24" long, it sticks out from the body and away from the wheels so you can't accidently hit the wheel or body if you slip. I thought the guy was nuts.
Today I removed my wheels with one of them being extreemly tight. NO PROBLEM AND NO DAMAGE AT ALL. The oak is apparently hard enough to impact the spinner and force it, and it is also soft enough to not damage the soft aluminum.
After taking them off and putting them on, I split the oak. Buy 2 or 3.
Hard to believe, but true!!! tom
Tom
I miss my Tazer
