Old 07-10-2008, 05:01 AM
patrickt patrickt is online now
Originally Posted by Maurice Butler View Post
The important thing is the clamping pressure on the splines. If you don't have clampling pressure and it is sitting there, the splines can round off and you end up with a bigger problem.
No, there is no clamping pressure on the splines. Note that there is a circumferential groove in the splined post. The set screw passes in to this groove and holds the arm on to the spline that way, not by clamping on to the splines. So long as the set screw does not break off, or back out, the arm will be fastened securely to the spline. Here is a close up that will let you see the groove.
