Old 07-10-2008, 08:18 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
If you are trying to make sure you do not taxi the electrical any more than you have to, you can put in a thermal switch in the block that kicks the pump on and off as required to maintain a temperature. I highly recommend a 30Amp or better relay to control the water pump with an over ride switch that forces it on all the time.
