To adjust the gas pedal, loosen the arm at the pedal box that attatches to your carb linkage just enough so it turns with some resistance. Raise the gas pedal to the height you want and tighten the arm. You may need to install a pedal stop so you don't bend any carb linkage.
The clutch pedal arm to master cylinder linkage rod is metric, would you know the thread size for the extender?
 Snakebit
