Old 07-11-2008, 04:38 PM
BDR561 BDR561 is offline
Cobra Make, Engine: BDR 559. 410 Stroker 72 block AFR205 Heads, Solid roller lifters, Comp Cams XR286, Eagle 4" stroke internally balanced with chevy journals, Oliver rods, Probe Forged pistons, Mighty Demon, Super Victor, MSD Digital 6.....
Haven't had it on the Dyno with the current set up (I lowered the C/R and bought the cam down a few notches so I could run pump gas)... I can only tell you that it is STRONG!!
Yep, I have tried several diffent setups with the different cars.... I still have too much power (if there is such a thing) for how I use the car... But there's not much out there that can keep up....
I do however like the linear power curve, it does help me keep traction which has been a problem in the past. You hold on and shut up from 3500rpm to 7000........
BDR 559
Indigo Blue, White Stripes
SBF 410
TKO 600 .82 OD (Road Race)
HP= Enough!!
