Old 07-13-2008, 11:58 AM
tamanaco's Avatar
tamanaco tamanaco is offline
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Default sticking throttle on a Holley 670 cfm Avenger
Need some help...throttle is sticking about 1/4 open. It has triple return spring, cable linkage that is loose, no pedal sticking...so it is the carb. So what do I look for? It's four years old with 7000 miles mounted on an air-gap clone manifold with a Ford racing oval air cleaner. If you tap the throttle hard, it returns to normal operation.
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
