  #23 (permalink)
Old 07-15-2008, 04:32 PM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
The six speed would be nice to cruise with a 3.5 diff at low revs
I've built my engine for torque and it revs to 6200 before it drops off on the dyno. It has a scat 4.5" crank, srp pistons, edelbrock heads, solid roller cam, roller rockers and balanced. It runs sweet even at 1500 rpm... Cam is 2500-6250 runs 10.3 comp Currently running an 850 demon carb
Im only using the Diff centre I've made a double wishbone setup and run outer brakes I'd like to cut a nine inch housing down and replace the jag...
