I install a #8 awg ground from the battery to a bus bar that I mount under the dash. I ground everything under the hood and dash to this ground bar.
Every time you ground to the frame be sure to grind off the paint and maybe use a conductive grease.
Dwight
and what Sal said
Sal
Tranny to frame, engine to frame, altenator to frame, regulator to valve cover bolt or frame. And of course the grounds from the wiring harness. Maybe more?
