Old 07-16-2008, 09:16 AM
undy's Avatar
undy undy is offline
Run the bad lifter down to zero lash (turn it into a solid) and spin the motor with a dial indicator on the rocker/valve. You can compare to another "known to be good" lifter/cam lobe. This will tell you at least if the cam lobe's gone away. At that point it's a moot point whether you can pull the lifter w/o pulling the intake
