Old 07-16-2008, 10:15 AM
FWB's Avatar
FWB FWB is offline
Originally Posted by undy View Post
Run the bad lifter down to zero lash (turn it into a solid) and spin the motor with a dial indicator on the rocker/valve. You can compare to another "known to be good" lifter/cam lobe. This will tell you at least if the cam lobe's gone away. At that point it's a moot point whether you can pull the lifter w/o pulling the intake
how do you run a feakin rocker down to zero lash on a hydraulic motor with
a rocker shaft?
that would be a good trick. number 1 lifter can be changed thru the oil fill
tube hole in the manifold. remove the tube or plug and use a lifter puller.
