more info
I am comparing my temps to other spf cobra with similar engines. Most seem to run at around 80 c , 90 c max. Mine runs 20 to 30 degrees hotter. Water temp is also around 90, about 10 degrees hotter than others. The max temp was 110, but I really was only going up and down the block a few times, I can't imagine what it would be when I really git into the motor aggressively. We are talking to the engine builder, and checking the specs they want, However I have seen some very good info on this board and figured I would see what Ideas anyone had. This was the first drive, with engine in car, so we want to make sure things are fine before putting it on the road. The engine builder was RDI.
Thanks again
Jason
