1000 lbs---how many dollars????
I would start off with a pair of torsion flex axles---best riding,most effsihant mounting
probably use some 2x6 retangle tubing for an perimeter frame, drop to 4 inch across rear for a slight droop,use 1 1/2 x 4 for inner rails and some aluminum for the runners with support under the wheel areas. use some earlier 14 in wheels so fender doesn't need to be too high
you will be pushing the 1000lb limit but its do able
