Old 07-23-2008, 11:04 PM
496fe 496fe is offline
Does the idle get better when the fans turn back off? In other words, is there an exact relationship between the fans turning on and off and the idle getting better and worse?
This is a wierd one. Also can you give us your cam valve timing and lobe center degrees.
