Thread: new stroker?
Old 10-05-2001, 06:18 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
427sharpe:
Engines run hot if there is not enough timming, not too much. Also the only way to see if the timming marker is accurate to the harrmonic balancer line is to bring number one cylinder to TDC and see if they line up. Not to be critical, your method will not work to prove accuracy, and should not be used to set the timing either.
JJF
