Old 10-06-2001, 09:10 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Mike, Is this the car purchased from Jim V. In Dallas? If it is Forget the other thread answer because I know the brake setup. The door releases are not stock Classic. They use a cable system that places the release handle next to the seat. I don't use them because of the failures I have had in the past. There are several options for the doors. You could use the cable system and put the handles anywhere you want, you can also install electric door solenoids and have a remote opener. The trunk latch is in the stock Classic location. You could have a handle similar to the original but it needs to be placed in the corner of the lid. There is no room between the license plate and the lid for placement in the center. I have done dual handles (1 in each corner) which looks ok. Give me a call and I can give you more information on the brakes and the trunk latch.
Don 1-888-722-6272
