Thread: canton oilpan
Old 07-27-2008, 03:00 PM
lineslinger's Avatar
lineslinger lineslinger is offline
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
I used the one that came with the engine. I had to put a small passage hole in the windage tray and make sure it wasn't rubbing against the crank.
I know the amount of oil required for the engine so I fill it a quart below capacity, insert a dry stick and score a mark. Then fill it to max capacity and score another mark on the stick for a high-low overall reference. I have the same pan you do.
