I drove mine sort of easy for about a week as I checked all bolts and for any leaks. Only had one small water leak and that was fixed by tightening the bold a fraction more. Look at all
oil lines and other connections such as gas after you have driven it and gotten everything up to temperature. I wouldn't push it really hard for a day or so just in case a hose or something decides to blow off or you got a faulty one and I have seen that happen. Then each day after driving it and parking it, wait a while and look under for any drips or anything and be sure to check all fluid levels. Also if you have aluminum intake and heads, it wouldn't hurt to check the torque on the bolts every so often.
