Old 07-30-2008, 08:58 PM
SoTxButler's Avatar
SoTxButler SoTxButler is offline
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
What kind of FI are you thinking of? I have an FE with high riser heads with stack injection.
If you are thinking throttle body, it should bolt right up to your high riser manifold. I have a Dove "tall and terrible" that I was running before the stack system. You could weld bungs for the injectors.
Russ
