Originally Posted by cdnus
Looking at your photos one can see clearly there is at least a portion of unthreaded area of the hub inside the spinner. On mine that is quite wide ( I will have to go out to the shop & measure to be exact ) if yours is the same you do not have enough thread holding the spinner on.
Craig
Went out & measured---3/4" protruding out of spinner.
1/2" unthreaded starter nipple--approx 2 threds=1/4" Total--3/4"
So if yours are manufactured the same, you do not have proper thread engagememt
Craig
The first thread from the outside of my hub is 1/4" in from the end. The outer most thread on the spinner is recessed about 3/8ths so trust me, they are fully engaged and the wheels are sitting flat against the hubs. The spinners from Vintage Wheels are deeper than most with more threads and yes, there was a change in the hub dimensions at Vintage Wheels.
