Old 07-31-2008, 09:14 PM
jeffsFE jeffsFE is offline
Thanks for writing back,the motor doesn't smoke at all but a friend thought that the heads might have been milled too much and with stock rockers might be keeping the valves open but the pushrods are spinning on all rockers,so not too tight. Also I found out the dist. was set at 36 dregrees and the initial was at 12,way too high at 48 total. I put the timing at TDC and the rotor was in between #1 and #5 on the cap. Does that mean its one tooth off on the dist. or timing chain?.
