Originally Posted by Excaliber
Wow, I'm impressed! Like ZOERA said, you got some good stuff, I'd stay the course, and that includes the '69 FE block. I'd also go flat tappet cam, myself, NOT a solid roller for sure! You do have the option of looking into a hydraulic roller as the 69 block would support that. Once you figure out your peak rpm range (6000-6500?) then you can start to match the heads to that number.
That's exactly my thinking, sort out the RPM range (you hit the nail on the head at 6-6500) and build it out from there.
I want to DRIVE to the track and 'run what I brung', not screw around with slicks or whatever.
I have been bored out of my mind since coming to Houston in 2004...and so living only 60 miles from the world famous
Texas World Speedway I want to be able to drive up, run the track and drive home.
Thanks for the feedback on this.
