Did you degree the cam when it was installed?? If not, I would have to wonder about the cam timing/timing gear set up. Non adjustable rockers can create an issue, but the times I've seen it was after a higher rpm run. Usually not at low rpm, although if they are far enough off it could possibly be causing the problem.
WDZ
