Old 08-01-2008, 12:04 PM
jeffsFE jeffsFE is offline
I'm going to take the timing cover off this weekend and check it then,but when I put it together it was striaght up. Hopefully the new timing tap is correct. I guess if the chain is correct I'll just move the dist. back a tooth. Have you guys ever looked at the cams in these motors before you put in the cam spacer on,it seems like the cam sits back to far the lifters to ride on the cam lubes correctly. Also there was a popping noise from the right side of the motor. Probably because it's not timed right.The sparkplugs are very white at this point,I'm going to have to jet up the carb. It only has #70 in the front bowls.
