Old 08-01-2008, 10:50 PM
Larry Ruppert Larry Ruppert is offline
Default 1969 Lincoln MarkIII 460 crank driven p/s pump
my donor car a 1969 lincoln mark 3 with a 460 has a power steering pump built into the timing chain cover and is driven by the crankshaft. the harmonic balancer has grooves cut into it and is the lower pulley for the air conditioning compressor and alternator, fan belt. my question is, is this a special crank or do all 460s use the same the same crank? if I get a crank spacer and a harmonic balancer off an early Ford 460. will this crank except these parts and can I then use the pulleys and brackets for the alternator and power steering pump off any Ford or Mercury with V-belt or a late model ford truck with a serpentine belt
