Old 08-02-2008, 07:04 AM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
Originally Posted by philminotti View Post
I'm trying to pick a Powermaster alternator for my FE 482 build. Looking through the various models that Summit offers, there appears to be two case styles for the FE...Powermaster custom and Ford 1G. The Powermaster custom style appears to be larger in "depth" than the Ford 1G style.
Does the larger dimensions of the custom style cause any interference problems? How about pulley offset for belt alignment? Thanks.
phil
Phil,
I have the deeper Powermaster alternator (100A 1 wire) on my 482 FE. It will not fit with the standard 1V pulley setup. What you need to do if you want to use the bigger alternator is to get a 2V pulley set and then use spacers to shim out the mounting points on alternator to fit. I had the unused groove machined off the top pulley to improve the appearance of the final setup. If you look closely, you can see the results in these pictures. The pulleys and brackets came from March.
Hope this helps.
- Fred
