I still haven't put the motor back together yet. I just read the last post and wondered about the cam spacer because the cam spocket does set inside the thrust plate about the same as the spacer thicknest. Is this correct??. I wish I know how to send a picture of this washer to you guys,but I'm sure you guys know what it looks like right?. Its just a thick washer that has a 1/4 inch peace cut out of it for the cam pin to stick out into the cam spocket. If thats the case then I will not have to take the gears apart. Let me know guys k.
Jeff from Idaho
