Tach, Fuel Filler Pipe and Roll Bar
1. Does anyone have a like new tachometer from the supplied Faria set that they don't plan on using? It seems like mine doesn't want to work properly.
2. What did everyone use to complete the fuel neck? I have the supplied metal pipe that screws onto the tank and the piece of rupper hose but nothing to connect this to the body. What goes under the lemans cap?
3. It seems like there are 2 possibilities for roll bar hight. Did you mount the bars that weld to chassis with the predrilled holes up high or did you turn them around bringing the bolt holes down lower? I am short, so both would work from a safety point of view, just want to get the proper look.
Thanks for your help,
Corey C
