Old 08-05-2008, 05:04 AM
D&M2 D&M2 is offline
Cobra Make, Engine: B&B, York 351W (Work in Progress), 07 Shelby GT # 0767, 09 Shelby GT500, 09 Shelby GT500KR #440
I had a custom tank built so in my case I just have a hose that extends from the cap to the tank inlet. I'm not sure what type of lemans cap you have as there are a couple of different styles. The quick fill type is all one piece with the neck that extends thru the body. The other types either used twist on filler or an open filler, either of which fit inside the lemans cap. In any case, there should be a bent tube that gets cut to fit in the middle and then the rubber hose connects on either side to the filler neck and the tank completing the installation.
I installed my roll bars as high as possible due to my height. Even installing them so the holes where as high as possible, they could have still been a little taller yet.
Mike
