  #43 (permalink)
Old 08-05-2008, 07:34 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Excaliber View Post
Now based on your theory/ET calculations that horse power ALWAYS equals a known ET and Trap speed I guess 800 horse would put me in the 9's? Unless you were STILL running tires that won't hook up and gearing where you shift into fourth AT the finish line or stay in third and 'run it out the back door'. What ever horse power you got if you can't hook it up, ET calculations are worthless.
Actually 600 HP should put you into the 9's with slicks, in the 10's with street tires, mid 10's give or take several tenths. Your trap speed should be about 130+ mph with a 600hp motor, about 120+ mph ( about 10 mph slower) with a 500hp motor. It's true that ET's are very variable,but the trap speed should be somewhat consistant whether you are using slicks or street tires.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
