  #22 (permalink)
Old 08-07-2008, 12:07 PM
JayBar's Avatar
JayBar JayBar is offline
Cobra Make, Engine: BDR#078,408 Dart Block, TKO 600,Indigo Blue, White Stripe
Send a message via Yahoo to JayBar
Here is my slave setup with the Termic TKO 600 with a McLeod steel pressure plate. The setup is not my design but one Reg and David came up with. The only thing needed beside the "puller" slave is a brass bushing to insert in the hole normally reserved for the clutch cable, it cars so equipped. I went through several brand name slaves. Seems the rod was screwed into the piston, and this would come undone. Yes even with lock tite, it came apart.
I bought a slave from www.speedwaymotors.com much cheaper and the rod is "peened" to the piston so it can't come out.
JayB
Jupiter, FL
