Please remember that the brake and clutch use different fluids in the BDR (at least most do). They are not compatible. The brakes use the DOT 5 (
synthetic) fluid. It does not absorb moisture. If you don't bleed the brakes the moisture will accumulate in the calipers and cause problems.
