Thread: Clutch
Old 08-08-2008, 03:46 AM
Tony Radford's Avatar
Tony Radford Tony Radford is offline
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
I've been plagued with this issue for years. The black fluid is likely caused by aluminum being rubbed into the fluid - like the black residue that accumulates on a rag while polishing aluminum. It eventually destroys the O rings in the master and slave. Also, if you use DOT5 synthetic fluid, the same thing can happen. Check both to see if fluid is getting around the piston seals. Replace one or both depending on what you find. It will just keep getting worse. It it's not the fluid, you may be overdriving your master by exceeding the max travel.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
