Thread: Clutch
Old 08-08-2008, 04:57 AM
strictlypersonl strictlypersonl is offline
The problem is most likely the clutch master cylinder drawing in a minute bit of air each time it's released. A bad slave cylinder will leak fluid out the end.
Both the master and slave are iron, not aluminum. Sometimes the rubber feed hose will turn the fluid darker. No big deal.
