Old 08-09-2008, 07:40 PM
iwantacobra427's Avatar
iwantacobra427 iwantacobra427 is offline
Cobra Make, Engine: SOLD: ERA FIA #2114 with 331
Default Holley Carb Vacuum Hookups
There are three vacuum hookups on my carb: timed spark, manifold, and power brake. My MSD distributor has vac advance so that hooks up to the timing vac. Where do I connect the manifold hookup on the Air Gap intake manifold? Also, are you guys using power brake vac or should I just cap it off on the carb? I don't think my master brake cylinder is designed to work with vacuum boost. I don't see any way of hooking up a vac line to the brake master cylinder..
