Old 08-10-2008, 09:28 AM
RichMusson RichMusson is offline
Cobra Make, Engine: FFR - Blue W/ Silver Stripe
Jerry
The battery is a duals post version.
Not too sure which fans you mean; probably all of them. The radiator fan is switched using an aftermarket product. It comes on when the water reaches a certain temperature. It has an override switch which is really just a toggle into what otherwise would be the air conditioning switch. The heater and foot-box fans are controlled by a toggle on the dash.
None of the fans were running when the car shutdown.
I do not have underdrive pulleys.
The entire gas delivery system has SS braided line. The fuel pump is in the gas tank and since it is EFI there is a return line. So lots of SS lines.
