Old 08-10-2008, 08:37 PM
fsiewert's Avatar
fsiewert fsiewert is offline
Cobra Make, Engine: Old ('93)CMC kit, SB ford
Check the battery cable clamps.....are they tight on the battery? You could chase this problem forever and it might just be a little carossion between the battery cable and the battery terminal. and its the easiest thing to fix! It can also cause the battery and cables to be hot. Corrosion = resistence = heat You did have moisture inside the distributer. Could be at the battery too.
Fred
