Originally Posted by Double Venom
cpteddie,
Made-4-you showed up very first thign this morning. Already drilled and tapped the frame for the battery cables so just about perfect timing. Ground strap was put on the motor, will box in the frame then weld up the second motor mount so it will all go back together. Soon as I get it done I'll run the mounts, tranny support up to John (Same as the electrical guy) and get them re-powder coated. Hopefully by tomorrow it, (the frame) will be totally done then just the alignment for the rear end!
DV
Thanks for the update, DV!!!
Any change of thought with regards to the pipe bender?
