Thread: 351W rockers.
Old 08-11-2008, 07:05 PM
blykins blykins is offline
That's not really a large cam. The lift isn't much at all....but of course if your pistons don't have enough piston/valve clearance, it doesn't matter how much lift you have. Did you check piston/valve clearance when you installed?
One thing that you haven't mentioned is whether or not the cam is a roller or flat tappet cam.
If it's a roller, that will eliminate the idea of the cam going flat.
If it's a flat tappet, I would put a dial indicator on a lobe and see if you still have the lift that you should have.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
