Old 08-13-2008, 08:39 AM
Cobra #42's Avatar
Cobra #42 Cobra #42 is offline
Cobra Make, Engine: Superformance Roush 427
Default Hole in Bell Housing
TX, Sounds like you have internal operated throw out bearing, if so a little trick I learned many years ago is to enlarge the access opening. That way you don't have to remove the trans anytime there is a problem with the internal throw out bearing. And you will have problems, trust me, be sure and make the opening large enough to get you big hand and wrench inside. Tip of the day, db
Don Barnes
Driving Instructor
texasdrivingexperience.com
Texas Motor Speedway
