Quote from Clois:
"Also, you will probably want a spring rate of about 250#-300#. You can softern this up with the adjustable dampner that is available on some models of coil overs."
Clois
Clois, Are you saying a total rear spring weight of 250-300 lbs. or is that the rate for EACH spring?
I need to get this information correct.
Thanks, Don
