|    Not Ranked
 If you have aftermarket heads on the motor it may be possible that the heads were shaved or the deck and valve clearance is not the same. I would suggest geting thicker head gaskets before buying anthing pricey. The cam you purchesed my be for a stock head motor, it would have more clearance. If its not stalling the motor out i think you can get away with just the gasket. |
