The motor mounts are supplied by Backdraft. You'll need to jack up one side of the motor and remove the motor mount. Double check to see if the rubber bushing has come loose. If not, then check the other side. If you do one side at a time, then you can easily do it with a jack and a board to spread the load.
Bests, James
Radical Roadsters of Texas LLC
www.radicalroadsters.com
Backdraft Racing Dealer
281-804-5730
Watch out! You may get BIT!!!
