Steve R;
Mine has the MGB front end. I have seen a lot of their front ends & have put a few of them togeather, which is why I'm fermilure with them. They had a couple that the bushings frose up and broke the bracket the same way before they started putting in grease fittings. Jorgen's looks like it has grease fittings. In trying to figure what happened I just noticed the machined side of the shaft was showing. The side that should be down is only spot faced for the bolt to seat on. From what I can see the arm don't look in to bad of shape, maybe just new bushings. The later front ends have the shafts drilled & tapped for a bolt & washer like the upper shaft instead of a cir-clip.
Poorboy
