Check the carbs (primary bowls) and be sure they have fuel. Check accelerator pump nozzels and be sure fuel comes out when throttle is opened. It is possible the float level is too low. Another long shot that if metering plates or blocks were removed that the incorrect gaskets were used between them and the main body. This asumes you have spark.
Rick
