Originally Posted by slitherv10
Hello,
I have a Ford FE 427 with a remote oil cooler and fan.My water temp is around 140 degrees but oil temp shows to be running over 300 degrees.Cruising at about 50 mph and weather was 80 degrees. Oil level is fine.Any ideas what could be the problem?Thanks in advance.
Dave D.
Before you do anything rash, get a little infrared pyrometer at Lowes, Home Depot, or the like and take a quick temperature reading on the inlet and outlet of your oil cooler (you just point and pull the trigger). That will help you get a double-check on the temperature of your oil just in case your gauge is giving you a false reading.
