Old 08-19-2008, 08:07 PM
Keithc8 Keithc8 is offline
If you have a vibration, unbolt and turn to next bolt holes. You have three possible combinations on how it will bolt to the flywheel. When we balance the pressure plate we will bolt in all three directions to find the closes. Most pressure plates have stand inside the springs that can be drilled on from the top. We balance the flywheel and then check the pressure plate. In about 1 out of 20 installs you will have a vibration and I am normally the one that has the viration. You will probably be ok but they can be off sometimes. We stamp our pressure plates if we balance them so they will get bolted on the same way as balanced. Thanks, Keith Craft
Keith C
