cutting back the side electrode
is an old lawnmower trick.
It helps the motor run cleaner at lower rpm with a fat fuel mixture....(with mechanical injection for example).
The suffix J Champions were in fact pre cut back and saved some filing.
With todays wider heat ranges and finewire pug availibilities all of that is out the window now.
